My camera is showing "lens error/restart camera", how do I fix it?
My camera is giving me a "lens error/restart camera" message and the shutter seems to be a bit opened. How do I solve this problem?
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
You are experiencing a common error. Normally this is a problem with the lens extension mechanism that is activated when the camera starts. This can normally be attributed to a dirty camera case or other grit getting into the camera mechanism. Other possible sources are physical jarring during operation or low battery during operation. The fist thing you should do is remove the existing batteries and the memory card from the camera, wait one minute and then put the batteries and the memory card back again into their compartment. Next, turn the camera on. Another possible solution is to blow compressed air around the lens mechanism, or a hair dryer on a no heat setting. Also, you can slide a piece of paper around the lens area and move it around the gaps in an effort to dislodge anything stuck in there.
Commentaires:
Thank you for your tips. I tried all of the above and still nothing :( I'm lost without my Canon Powershot SX120 IS as I never leave the house without it lol I will continue my search for an answer, as I'm leaving Aug. 1st for a beautiful sailboat trip to do some fishing..if by chance I find another way to fix this problem, I'll post it..
Thanks again...
Joanne
par jojo
Thanks so much!! Your solution worked for me!
par Albert Kamanzi
Same problem lens not coming out showing lens error don't know what to do pl help can I go to the service center please help
par Laila
Oh, Thank you so much ! This was helping ! The (old) camera functions again ! Marvellous ! Thank you so much ! :)
Laying the camera flat on its back (lens up) and tapping it gently on a tabletop during startup caused the lens to finally open up.
par grimble
I went through this on mine. Get it serviced, once they are serviced right by a technician, the cameras perform beautifully. I think they just don't always come out of production perfectly. The place I would recommend (I've used them twice and they are exceptional for Canons - it's all they service) is: www.CamerasAndParts.com They are very affordable as they have flat rate service packages, their work is superb. Never had a problem with either camera after service, they do some tweaks to make them better than the way they come from production. I would really recommend them if you need help with this lens error problem.
Commentaires:
Same problem with mine lens not coming out just today I went too fixed it I was there when I saw it display after fixing it thought all was cool later when I got home tried too see it yea it work I put in my SD card minutes later it started showing lens error again really kinda stress right now
par sillahmusa478
I DO NOT RECOMEND DOING WHAT I DID to fix my error but i took the bottom of the lens and whacked it kinda hard on my thigh and i heard a crack, turns out i think my lens over extended and i set it back in place
Commentaires:
It worked for me also
par JYOTI SAWHNEY
Thank you for the thigh trick. I was about to give up and tried this and it worked.
par music
I have a Fujifilm XA3, There is an error message “Turn off and then turn back on again”. I already sent it to the service center for a week ago now after that the camera works smoothly but now, the error message shown up again.
Good morning;
The tip for taking a piece of paper and running it around the lens and then tapping on the table remedied my problem. Thank you very much for your greatly appreciated professional opinion!
Have a most pleasant and enjoyable day
Best
Thomas H. Bennett 111
Rep: 1
I had the same problem with my Powershot SX120.
I found that the spring for the batteries had gone a bit down. Fixed that and problem seems to be solved.
Rep: 1
Do:
Clean the Lens and if something is obstructing the lens movement, remove that to fix EOS error.
Rep: 1
with what must I clean my camera lens
Commentaires:
Canon power shot Sx20IS when I try to on it’s showing lens error try to restart any solution ??
par Zuaif Tech
Rep: 1
Help my camera has the same error and none of the tips are working! I’m a youtuber and need help
Rep: 1
Point it down to the floor as if u r picturing the floor and press those buttons again. A miracle will happen then.
Rep: 1
My daughter had this problem with her Canon SX20-IS. Her lens was stuck at full extension. I tried all of the fixes and nothing worked.
She accidentally left it in her car overnight, where it got below freezing. The next day, it started working!
It might sound crazy, but if all else fails, try sticking it in the freezer for a couple hours. Not sure if this could possibly damage camera or not.
Rep: 1
flex powersupply/ flex top cover crack
Dernières 24 heures : 28
7 derniers jours : 176
30 derniers jours : 806
Total : 80,027
I'm also experiencing this error message, however...
• the camera turns on,
• the lens extends outwards,
• the lens contracts inwards,
• the camera turns off...
I did notice the superficial disfigurement that is on the outer shell of the lens, but this shouldn't cause this error as on occasions, the camera turns on, the lens extends outwards, and I can snap a few pictures, unless I aim the camera in any direction other than straight ahead - if not straight ahead, the lens contracts inwards & camera turns off.
par Frae Guile
Try pointing the camera at the ground. This works for me EVERY time. Gravity is a ##&&%.
par Timothy Burr
I just got this error and had no clue what to do. tried pointing it at the ground and it worked! Thanks so much!
par merznc
My lens cover does not open?
par Judy
hi i have x50 and my wife droped it when it was on I need to take it apart and fix it any tips?
par Si Lythgoe
Voir 5 commentaires en plus
