Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Questions au sujet de 244 Voir tout
Installed 2nd battery but won't charge. Bad internal charger?
The "Possibly Related Questions" box contains existing text I can't erase.
Re iPod 4th Generation:
Charge graphic blinks and indicates a charge in progress but never happens. I've left it charging for several hours; No charge. I'm sure the battery is not defective.
Is there an internal charger part that could be defective? And is it a replaceable part?
Thank you
Crocdog
Répondre à cette question J'ai le même problème
Score 1
Ajouter un commentaire
Manta Precision Bit Set
112 embouts pour toute réparation.
Upgrade Your Toolbox
1 solution
Réponse la plus utile
Crocdog, try to charge it with a Firewire charger. Check to make sure that your dock connector is clean, no debris, bend or corroded pins. You can also check the battery connector with the iPod plugged in to see if you receive any power from that. It should be around 4.2V-4.6V. Check the dock connector with a multimeter and see what voltages you get. The pinout for the dock connector can be found here. Yes, there are plenty of charging components on the logic board. All of them are SMC and would require a sound knowledge of soldering as well as the right tools. Hope this helps, good luck.
Cette réponse a-t-elle été utile ?
Score 1
Commentaires:
Re: Crocdog charging the A1099 /20GB Ipod
Thank you O.T.03!
The docking connector answer worked perfect. It charged right up away.
The poor thing is now healthy and holding on to a charge...Saved from the bone yard!
Thanks again...
Crocdog
par
Crocdog, you are welcome. Best of luck to you.
par
Ajouter une réponse
Crocdog sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 262
