Aller au contenu principal
Intel Core i5 bicœur avec 3 Mo de mémoire cache L3 de 1,8 GHz
Water spilled on my laptop and now became very slow
Water spilled on my laptop and now became very slow and work through the charger and the battery just do not charge also...And I want you to help me to know how to fix it ???
Répondre à cette question J'ai le même problème
Indice 6
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Follow the tags at right and you'll see what you're in for (major DIY project). Easier way (still very advanced as you have to completely disassemble and reassemble the entire machine) replace the logic board. (You might even be able to upgrade to the latest processor/graphics package for your model year if you own a base model).
If this answer is acceptable please remember to return and mark it.
Indice 3
5 commentaires:
It happened two months ago, the keyboard still works and the water did not enter on the keyboard and the screen also !!
par
But the battery was not working and change it with a new one did not work well and are there programs to increase the speed of the Mac
par
There are no software fixes for hardware issues - if the slowness is because you have less than 10GB of empty space on your boot volume, remove large files until you have more than 10GB free.
par
I've cleaned the mac inside and become better and improved speed, but not like before damage ..The problem now is the battery i see the battery information the Cycle count: 388 and the condition: normal ...!!!
par
Yes the newer Apple Batteries can last up to 1000 cycles though performance will deteriorate as you reach the end of life.
par
I also have the same issue. It's faulty temp sensor in the trackpad. I just replaced the logic board and realized that it wasn't the board to begin with but the sensor.
I had two other customer laptops with the same exact issue (very slow, fans running high, SMC error in the diagnostics). Apparently the way the liquid spills, it hits the trackpad area.
Indice 1
How can I know whether the faulty temperature sensor is in the trackpad or somewhere else?
AHT error reference codes: PFM006, NDC001, PPN001
MacBook Air 7,2 (early 2015)
Damage occoured while it was in a backpack with a leaky water bottle.
Fan is on max. kernel_task is using around 2-12 % CPU.
Indice 0
1 commentaire:
I would give this utility a try as its much clearer than AHT on whats happing: TG Pro for less than $20 US its worth it.
par
Ajouter une réponse
aziz mneer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 32
Total : 27,306
