Aller au contenu principal
Écran de 7,9 pouces / Modèle A1432 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012/ avec 16, 32 ou 64 Go de capacité
Replaced cracked digitizer now left screen won't work.
Hello I replaced my iPad mini wifi digitizer, I still have not glued it down, the screen comes on and can unlock it, but it start to act crazy by opening apps on it's own, pressing buttons on it's own, swiping left and right on it's own too. The left side of the screen will not respond either. Help please. Thank you.
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi, try unplugging the digitizer cables and re-plugging them again. Then do a hard reset on the iPad by holding the Power and Home buttons for around 12 seconds. If that doesn't work and everything is connected correctly, it is possible that you might have received a defective replacement screen digitizer.
Indice 2
1 commentaire:
It re-seating the cable and hard-rebooting doesn't solve it, I then agree with Jose that you have a defective digitizer assembly, and it could be that you teared or pinched the cable of the digitizer when handling/installing. Watch out if/when you try installing a new digitizer, especially be careful not to pull hard on the cable in any way, or to pinch it between the glass and the aluminum frame for example.
Good luck! iPad Mini's are a pain...
par
Ajouter une réponse
Rankin Gilmour sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 526
