Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Questions au sujet de 585 Voir tout
Black screen after video card replacement.
Hi,
I bought a new video card from a reputable dealer (Macpartsonline) and followed the advice on this page iMac Intel 20" EMC 2133 and 2210 Video Card Replacement up to step 38, because the new video card had a heat sink attached. I replaced the video card unit and reversed the steps. Now when I start up the computer I hear the chime and fans whirring, but get a black screen. Is there some cable I didn't reconnect correctly?
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
If you are 100% certain you put the card in correctly and all cables have good connections you probably have the wrong EFI in the computer… especially if the card is not an exact match for the one you removed.
Other possibility is wrong extension (aka driver). This one is easier to test. See if you can boot from an install disk (has more drivers - generic drivers). If so do a OS reinstall.
If this answer is acceptable please remember to return and mark it.
Cette réponse est utile ?
Score 2
Commentaires:
It's not the exact match but seller said it's compatible.
My iMac is chipset model ATI Radeon HD 2600 Pro, Processor: 2.66GHz Intel Core 2.
The card I bought is ATI Radeon HD 2600XT...
Is this a problem? Are they incompatible?
Philip
par
PS: Thanks for the advice. Didn't get a chance to try booting up from the install disk last night - will try tonight. I also forgot to add that the 1st two diagnostic LEDs light up but the 3rd and 4th don't.
par
Here's a tech note about EFI note its for a MacPro series. A link about the "reliability?" of that card... I wouldn't know how you can verify it's a good one.
par
I tried booting from the install CD. It sounds like it is booting up, but I can't see what is happening because the screen is totally black. Again, the 3rd diagnostic LED is not lighting up, indicating the video card and computer are NOT communicating.
I figured I would put my old video card back in and endure the faulty pixelated display while I download the driver update, and then put the new video card back in.
However, after putting the old video card back in, I am now getting a black screen on start up and the 3rd LED is not lighting up...
Your first sentence was "If you are 100% certain you put the card in correctly and all cables have good connections"... I'm not so sure now... I think something is not connected right. I suspect it might be the inverter cables attached to the back of the screen.
par
Step 11 of the guide is extremely vague. It says "During reassembly, the order of the inverter cables is interchangeable within each socket." Is this true? I have a feeling there is a preferable order and I've got it wrong...
par
Voir 2 commentaires en plus
Ajoutez une réponse
Philip Sneyd sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 24
Total : 1,215
