Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Questions au sujet de 585 Voir tout
Logic Board or Power Supply or Hard disk Failure?
Hi all,
My iMac EMC 2210 is unable to boot at all.
Trying to find out whether it's a logic board or power supply failure.
I have just replaced my hard disk approximately 1 year ago but I am not writing it off the equation.
Pressed the power button but has no chime nor visual.
I could hear the fan sound (but couldn't be sure if it's the fan or hard disk).
Any guidance is greatly appreciated.
Une réponse ! View the answer J'ai le même problème
Commentaires:
Update / Additional Info
I left the iMac off for a couple of hours and managed to boot it for now.
Is it overheating ?
par
Can you give us the last three digits of your systems serial number so we can correctly identify your system.
par
Hi Dan,
Thanks for the prompt reply.
Last 3 digit of serial is ZE3
Model 1224 , EMC 2210.
Didn't manage to use Temperature gauge pro due to my comp is officially dead once more.
par
Apple iMac "Core 2 Duo" 2.66 20-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB324LL/A - iMac8,1 - A1224 - 2210
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 réponse
Solution retenue
To check if the system is over heating you'll need to install an app which can read the fan & temp sensors in your system. Give this app a try: Temperature Gauge Pro There are others but I have found this one to be one of the best. Let us know what you find after running it.
Cette réponse est utile ?
Score 1
Commentaires:
Hi Dan, Thanks for the prompt reply. Last 3 digit of serial is ZE3 Model 1224 , EMC 2210. Didn't manage to use Temperature gauge pro due to my comp is officially dead once more.
Chee Yong Koo, 11 hours ago
Apple iMac "Core 2 Duo" 2.66 20-Inch (Early 2008) Specs Identifiers: Early 2008 - MB324LL/A - iMac8,1 - A1224 - 2210
par
Starting to should like your power supply has issues. At this point I think you'll need to open the system up to inspect things. Are you up to that? Review the IFIXIT guides and setup your work area if you haven't already.
par
Yes, I am ready to open up. Any guide is appreciated.
par
Follow this link: iMac 20" repair guides
par
Thanks for the guide.
I have no issues replacing the hardware as required but the main issue here is that I couldn't rectify if it is a Power Supply failure or Logic Board.
Any ideas?
par
Voir 5 commentaires en plus
Ajoutez une réponse
Chee Yong Koo sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 250
