Aller au contenu principal
La ligne d'ordinateurs portables MacBook Pro a été conçue pour les utilisateurs professionnels. La gamme MacBook Pro inclut le MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", et le MacBook Pro 17" Unibody .
Questions au sujet de 15101 Voir tout
MacBook Pro Disk Utility emergency backup
MacBook Pro Disk Utility emergency backup?
I'm having some major issues!
My MacBook decided to melt down, and freeze on the gray apple logo screen. After a week of trying safe startup and tons of other tricks, I decided to wipe out my computer and start again.
I really wanted to save some pictures and documents, so I tried using Disk Utility to create a "image" on an external hard drive (I found this tutorial online). I clicked "scan image for restore" as instructed, and after waiting for over an hour I received the error message "unable to scan - internal error"
It's a MacBook Pro running on Mavericks.
Any advice is so appreciated. I would love to resolve this without loosing everything!
Thanks!
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
I would create a USB boot drive, boot from it then try to backup your images and documents folder by drag/drop onto an external drive. (Now you know why you should keep a current backup of such essential data)
The apparent source of your problem is a failed or scrambled SSD. Since you didn't state the age of the MBP I can't tell you if the other alternative. putting the SSD in an external case, would work.
Excellent third party disk repair apps are DiskWarrior, TechToolPro or Drive Genius3 they can often resurrect a badly master boot record (MBR) or volume boot record (VBR) on a drive. They can not repair physical damage.
If this answer is acceptable please remember to return and mark it.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Jess sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 731
