fuse location and type is the same for a Mid-2012 Retina 15"
I'm sorry, I'd like to add this as a related/follow-up question for oldturkey03, but I don't see an option to leave a comment on his answer. I'm wondering if the fuse location and type is the same for a Mid-2012 Retina 15" as for Sync's Late 2013 model. And if so, is there good info out there about replacing this fuse or a good place/person to do it that doesn't charge an arm and a leg (does iFixit offer a service)?
Thanks,
Fred
3 commentaires
The reason why there is no follow up. is because everyones question is individualized:-) what is your computers serial number? If you can see if you find a 820-XXXX number on your logic board. That will help us to properly identify your computer.
par oldturkey03
Thanks, oldturkey! Yes, I guess my question is individualized, but at the time it seemed like it might be good to associate it w/ the original post. :-)
The computer's serial # is C02J2204DKQ2. I do not see an 822-XXXX number on the bottom of the logic board (side exposed when bottom case is removed), but I can pull it again if the serial # is not sufficient. There does appear to be a MLB serial # between the keyboard and battery connectors: C02226700XSDRF1A0.
Thanks for any guidance you can provide in testing/repairing/replacing the fuse!
Fred
par Fred Turner
2.6 GHz Core i7 (I7-3720QM)
Intro Date: June 11, 2012 Disc Date: February 13, 2013
Order No: MC976LL/A Model No: A1398 (EMC 2512)
Subfamily: Retina Mid-2012 Model ID: MacBookPro10,1
Std RAM: 8 GB Std VRAM: 1 GB*
Std Storage: 512 GB SSD Std Optical: None*
par oldturkey03
