Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le premier de la nouvelle génération d'appareils Nokia – le premier avec un écran 1080p, le premier avec un processeur Krait quad-core
Glass on Camera is Broken
Hello, I dropped my phone, without a case (Dumb of me I now know), and the glass on the camera broke. Without it the light is not focused and the camera is not able to focus. I was wondering how to go about repairing that?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
6 Réponses
I'm not sure if you're talking about the digitizer or camera lens.
They list this lens for the 1520: http://www.ebay.com/itm/like/23122231482...
Here's the front glass.
http://www.ebay.com/itm/C-OEM-Outer-Scre...
Indice 1
Réponse la plus utile
Jake Miller, it looks like you are looking for the proverbial needle in the haystack. the plastic lens cover seems to be almost impossible to find by itself. At this time I'd suggest to try and find and replace the complete back cover.
Indice 1
1 commentaire:
does a back cover comes with this glass ....
par
Ia there a guide on here for that?
Indice 0
4 commentaires:
What is "that".
par
What was suggested by oldturkey3
par
I give up. What we have here is failure to communicate,
par
@Jake Miller, follow the first steps of this teardown. Démontage du Nokia Lumia 1520
par
Hello my lens is also broken but i found this:
http://www.parts4repair.com/nokia-lumia-...
But what i didn't know if i only could replace the lens or i need replace the backcover.
Indice 0
I found on eBay the lens cover with a removal toolhttp://m.ebay.com/itm?itemId=30127895455... now need replacement instructions
Indice 0
I am in the US. I bought one from ebay and then fixed it myself. Did not have to open the phone for this.
There are many products on ebay. I bought this one -
Product link:
http://www.ebay.com/itm/Replacement-Blac...
There were no instructions, but I contacted the seller and they told me how to.
Use a hair dryer to warm the tape under the bezel. Then use a cutter or thin knife with light force to cut off the adhesive at the edge of the lens.
P.S: Be careful with the tape that is provided. First remove the central circle so that you are left with just the donut. use a pair of tweezers for best results.
Indice 0
6 commentaires:
Good comment,I accidently left the center circle on the tape and installed the glass lmao.Pain in the @%^ to get back off!
par
Must give this a try. What is best way of removing the cracked camera glass ? thanks
par
I just removed it bit by bit. Even if you melt the adhesive, the glass pieces wont just fall off. They seem to be tightly set and need to be removed using the knife from the edges. No solution a to how to prevent tiny pieces from falling in :s
par
Thanks Sri,
I did manage removing all the little bits and replaced the glass. Looks fine and works fine apart from it can no longer focus on macro. Pity..
par
Where can I buy the camera glass???
par
Afficher 1 commentaire en plus
Ajouter une réponse
Jake Miller sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 18
Total : 6,121
