How can I replace my htc magic cover?
hi,
i want to purchase an OEM cover off ebay because the one i have now is cracked. can you help me with instructions on how to replace it?
Shayne
The HTC Magic is a smartphone designed and manufactured by HTC.
hi,
Shayne
If you want to replace the front panel you need to take apart almost the entire phone. Most of it can be done with a Torx T5 and T6 screwdriver and following logic. At the moment I can't make a guide for you since my phone got stolen today.. :(
The front cover is very easy, just go to the device page and click on the manual.
Replacing the front cover is easy, but I would absolutely not recommend to replace the body of the Magic. At least not with the housings that are sold on ebay. Reason is: the Bluetooth and GPS antennas are glued onto the body / middle part of the housing. You can see them as two stickers, one on the left and one the right side of the camera glass. Now, if you replace the body, BT and GPS won't work, because 99.9% of the housings sold on ebay don't contain these antennas and it's to risky to remove them from the original body.
You have three choices:
1. Get an original housing (don't ask me where because I don't know) and try to replace it.
2. Only replace the front case, which is a pretty easy operation. Just don't buy the housings with only the HTC logos, because they are built very bad:
- the vibrating motor will be stuck due to case design fail
- the thread inserts in the four corners are too small (I busted three of my four screws)
- the LEDs from the six buttons will shine through the case (although you can only see it in the night)
- and last but not least the included track ball will not work properly too
3. Try to make your own antennas. Someone did it and made a how-to:
http://forum.xda-developers.com/showpost...
He claims it's easy but I found it pretty hard and frustrating. It took me some hours but in the end it didn't even work and i ended up replacing only the front case.
Rep: 1
Yeah... for sure magic housing has it radio radio antennas stick on it but with a little patience you can remove them and stick it back.
Beware of the screws. I needed to remove the metal fittings and replace them with the old ones. Very hard to do.
Look after the vibrator. I had the replacement housing scratched a bit so the cam would rotate easily.
Remove the tape around the screen hole if you want the LCD to be at the same level with the case.
Use the old keys and paint the case black from inside if don't want to see the leds through the plastic.
Check the plastic diffuser of the upper leds. You may need to keep the old one if there are not identical.
Be careful with the volume key. It only fits one way and its rubber clips are easy to break.
Don't make any appointments for the next two or three hours. It's time consuming procedure.
All above are problems that i manage to fix but these are subject to case manufacture.If you are lucky you might not meet any of those.
I think there are 2 or 3 (except the original) different qualities.
Mine was HT-03A. Probably the worst.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5,897
As in the front panel?
par rab777hp
thanks for all the feedback guys! very helpful
par Shayne Dique
