Modèle A1419 / Fin 2012 / Processeur 2.9 & 3.2 GHz Core i5 ou 3.4 GHz Core i7, ID iMac13,2
Questions au sujet de 212 Voir tout
Why am I getting a broken folder icon?
Just replaced the 1TB HD with a 3TB from an older Mac but was also running Snow Leopard.
After several tries, I continued to get the broken icon icon on attempted boot up.
When I put the original HD back it booted up fine and likewise with the 3TB back in the late 2007 20-iMac
Are there HDD incompatiblitiy issues?
They are both Seagate 7200.
Please advise as have 2 torn apart iMac and need them up and running.
thank you in advance
Une réponse ! View the answer J'ai le même problème
Score 1
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
There may be OS compatibility issues if so this is a software, not hardware problem.
If you are seeing the circle with a slash through it the "system" is not (or files/kernels) are not compatible and a reinstall will correct it. If you are seeing the flashing "?" then there is no usable system folder (the old Mac may have been a PowerPC) or the HD is not mounting.
If this answer is acceptable please remember to return and mark it.
Cette réponse est utile ?
Score 3
Commentaires:
Thank you Machead3,
You are correct.
I shift+option R restarted and got the disk to load.
Thanks!!
par
Ajoutez une réponse
Davejp sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 232
