Aller au contenu principal
Modèle mi-2009 A1278 / Processeur Core 2 Duo 2.26 ou 2.53 GHz EMC 2326
745 questions Voir tout
Cannot erase format install OS
Old hard drive failed. Ordered new Toshiba 320 GB hard drive and installed. Attempted to install OS X on new drive. Cannot erase or partition drive. I get the error: Cannot Allocate Memory.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Check your SATA cable connections - it's possible you may need to replace the SATA cable if you damaged it taking out the old HDD.
If this answer is acceptable please remember to return and mark it.
Indice 1
2 commentaires:
Thanks... I was very careful with the cable during the fix....but I have ordered new cable. We'll see what happens. Hoping, at this point, that it was/is a bad cable originally...that way I end up with an extra HDD.
par
It could be - others have reported that sequence of events... if you have an extra working drive you can not return put it in an external case and use it as a backup drive.
par
Ajouter une réponse
wdneighbors sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 107
