Hi, have you performed a battery recalibration? To be honest no one battery apps are good, they just cancel some logs from your device (in few words) Here is how to perform a battery recalibration.
How to calibrate a smartphone battery: Let the device reach 0% and let it shut down till you can not even turn it on
Connect the battery rechargerwall and let the device reach 100% battery without turn it on.
Once the device reached the 100% battery let it connected for other 2 hours (without turn it on)
Once the 2 hours are passed with the rechargerwall battery connected to the electricy, turn on your device for 20 min, after that turn it off.
Once you turned off the device disconnect the rechargerwall from the wall then disconnect the usb data cable from rechargerwall battery. After that reconnect the usb data cable to the rechargerwall battery and then reconnect the rechargerwall battery to the wall electricity
This operation should be repeated for 3 days in a row. Do not perform this operation more than 3 times in 2 months.
Let me know
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
8 commentaires
how did u fix it. same problem for me also
par sam
Above same problem here , my phone is micromax a110 canvas 2, it is purchased in 2013, charging problem when mobile is switch on but start to charge when it kept off.
please send me the sollution. Service center in Sangli (Maharashtra) also unable to solve my problem.
Please help.
Santosh Waghmare
7875969379
par EE Kmahankal
I am also struggling with same problem with Micromax Canvas A110. It charged only in switch off mode. If anyone got solution to this problem, please share
par shalabhkesar
Pls sign this petiotion : https://www.change.org/p/micromax-india-...
par Nitin
I have a same problem like above with my Huawei G mini which I used for last 1.5 years. Now it does not charge when phone is on but it charged if the phone is off. please help me with this issue.
par Aftab Uddin
Voir 3 commentaires en plus
