Aller au contenu principal
La deuxième génération de l'iPad avec les modèles Wi-Fi, GSM et CDMA. Certains modèles ont été rafraîchis avant l'iPad 3. La réparation est difficile, nécessitant de chauffer les parties collées, ainsi que de la précision et de la concentration afin de judicieusement détacher les différents composants.
729 questions Voir tout
Wifi not working after repair
I while ago i had to replace my ipad after cracking the screen due to dropping it. Sinc replacing the screen the Wifi connection has been really poor and will not work outside the room my router is in. I have replaced the Wifi antenna twice buying a new antenna each time and still the wifi is very poor. Can someone help me please. Thankyou
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
The problem you are facing with poor wifi reception normally relates to the antenna being torn slightly or damage to the antenna board that plugs into the logic board,
Both of these are quite easily replaceable.
you said that you have replaced the antenna twice so the next step i would take is to replace the antenna board, whist you open the ipad check the antenna cable thoroughly to make sure it isn't torn slightly.
Where did you purchase the antenna's from and are they original parts or chaeper copy parts?
when there is a problem with the wifi it is normally related to one of the two solution i gave, if not both.
Indice 0
Ajouter une réponse
Andrew sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 171
