Loud banging noise only during spin cycle
My washing machine is making loud banging noises only when on the spin cycle. I have made a short video (I didn't want to break it!) including the noise.
Please let me know what you think it is.
I think I have narrowed the probelm down to either be a bearing, or transmission problem; but am unsure as to which.
Thank you for your time!
4 commentaires
On mine, I removed the agitator, under that I discover a "collar" that holds the tub to the agitator shaft had a broken bolt. I went to the hardware store, $.88 cents later the washer was fixed. I hope this might help someone, I feel lucky!
par john
Brandon was the clutch your problem on your washer? I'm having the exact same noise and curious if that was the solution or something else.
Thanks!
Jen
par jennifermbishop
Unfortunately that was not the problem for me. I replaced the clutch and nothing changed. I went in to a repair shop with my video, and they told me that the devil has possessed the machine. He then went on to explain that there is something wrong with the transmission, and the machine is effectively totalled. It would basically require a full transmission replacement, which requires you to put the transmission in a vice, to keep the oil from running out. However it is almost impossible to actually figure out what is wrong with it. Googling agreed.
This also intuitively makes sense because (for me at least) the machine worked great in the forward direction, and it was only when it tried to twist back that the sound occurred. The clutch simply slows the drum down when it is over spinning. I'd recommend putting a key or something in the safety catch and looking at the center stack as it begs for death.
Good luck Jen! But I think your money and time are better spent picking out a new washer.
-Brandon
par brandon bird
I had the exact same problem. The large plastic gear in the transmission failed; Many teeth stripped. Fixed by replacing that gear for about $25 in parts. Can be messy & takes modest labor for the mechanically inclined.
par fbk36
