Aller au contenu principal
Tutoriels de réparation et de démontage pour distributeurs d'eau.
Questions au sujet de 71 Voir tout
Cold water giving hot water
Need help, my water dispenser is giving me trouble, the supposedly cold water part is giving me a hot water. i don't know what to do.
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
Sadly it sounds like the compressor is going or the refrigerant has leaked out.
These are little mini heat pumps moving the heat from the water in one tank to another one creating cold & hot water (excess heat is also dumped into the air).
If the pump is not able to compress the refrigerant it is unable to remove the heat and could be doing the reverse here pushing heat in to the cold side. In any case it would be warm not hot water.
Cette réponse est utile ?
Score 2
Commentaires:
hello sir, thanks for the reply, any ideas on how to fix this problem of mine?
par
You'll need some special tools and access to the refrigerant your system uses. Not sure if it can be repaired. Best to bring it to an AC repair person to check out he will have the needed gear and refrigerant.
par
Ajoutez une réponse
Lucky sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 36
30 derniers jours : 185
Total : 4,571
