Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Troubleshooting information and disassembly guides for garbage disposals.
Kenmore garbage disposal - No sound, just won't turn on
What if you turn on the disposal & there is no sound, no hum? It didn't break down while in use, & I have tried to fix it--pushed button on bottom, checked for blockages, flipped breaker--to no avail. I don't have the right sized allen wrench for the hole in the bottom, but seemed to move around a bit & sound like it's got water in it when I tried another tool in said hole. I want to fix it myself before calling the landlord. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
I finally have the answer, it was a loose wire in the toggle switch housing. No idea why it came loose, vibration must have done it with use. Thank you for your suggestions.
Indice 2
1 commentaire:
My Kenmore disposer works (the motor works) but it stopped spinning
par
Start Switch
On some models the stopper activates the start switch which is mounted into the upper housing of the garbage disposer. If the disposer won't turn or run at all the switch might be defective. The start switch can be checked for continuity and replaced if necessary.
Other Causes and Conditions
Wall Switch
If the garbage disposer won't turn or run at all the wall switch might be defective.
Non Serviceable Motor
If the garbage disposer won't turn or run at all the motor might be defective. The motor is not replaceable. If the motor is dead the disposer will have to be replaced.
Indice 1
1 commentaire:
Please tell us what worked.
par
Ajouter une réponse
Trace sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 41
Total : 19,326
