Aller au contenu principal
Pour réparer ensemble - Je crée un compte
touch screen not resonding after replacement will not unlock
have replaced display screen boots up fine does not respond to touch to unlock why
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
I'm having the same issue. Have you found a solution?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
scott, the first thing I suggest for you to do , is to double check your work. Make sure everything is properly connected, check the connectors for any bend or broken pins. If all of that is fine, I would return the assembly and replace it once more. It is possible that you have a faulty one. Worst case scenario are logic board issues with the touchscreen IC. Hope this helps, good luck.
Indice 1
1 commentaire:
I agree with you and did exactly that, I have changed the assembly twice and still have the same issue. If it is the touchscreen IC what would have caused that to go bad? The customer did break his lcd which is what I was repairing. Any information you can give regarding the touchscreen IC will be appreciated. Not something I have had to deal with before.
par
make sure the screen replacement part works with android 4.4, that is a common problem
Indice 0
2 commentaires:
Having same issue think my new screen doesn't work with 4.4 is there a way to fix this with out being able to use the touchscreen ? Like how can I undo the update? Any ideas
par
flash older firmware through Odin, all firmware available at sammobil
par
Try reverting back before 4.4, go to Sammobile and find older firmware for your phone and then download a program called Odin. Load the .tar file in the PDA section, untick repartition and flash when ready. good luck! (you will loose all data so back up first)
if you want to do things on your phone you can plug a wired xbox 360 controller or a wired ps3 controller and control your device with that
Indice 0
Ajouter une réponse
scott sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 40
Total : 2,341
