Aller au contenu principal
Guides de réparation et de démontage pour Apple Time Capsule Modèle A1302. La plupart des informations s'applique également au modèle A1254.
Questions au sujet de 18 Voir tout
Broke the fan connector off logic board
In removing the bottom case I broke the fan connector off the logic board (I didn't see that it's not necessary to disconnect this, and while I thought I was being careful, apparently not).
One of the pads came up with the connector, so will repairing it require soldering onto a very thin trace? Is this likely to be successful?
Alternatively, is it viable to just keep the unit running without the fan and the bottom case? I'll be careful to keep my fingers away to avoid a shock.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
You could take it to a professional (computer logic board soldering is not like lamp cord or speaker wire soldering) Soldering logic board components/connectors requires special tools, solder and lots and lots of practice (it's easy to burn up boards with too much heat).
Not every step in a DIY repair has to be done by you.
If this answer is acceptable please remember to return and mark it.
Indice 1
Ajouter une réponse
Mikael S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 299
