Jumping Rotary switch to power on NEC NP-M300X
I'm trying to fix a nec np-m300x projector for our youth that is out of warranty. It won't power up and the code it gives is that the lamp door needs to be shut even though it is properly shut. Upon tear down, it appears the switch (I assume a rotary switch) that the lamp door makes contact with on the circuit board is physically damaged. In speaking with a repair shop an hour away, I was advised to jump/bypass this switch as it is merely a fail safe to keep people from operating the projector with the lamp door open. How do I go about doing this?
1 commentaire
Kevin, should be straight forward. Post a couple of images with your question so we can see what you see. This way we might be able to point things out a bit better. Use this guide Ajout d'images à une question existante to help you with posting some images.
par oldturkey03
