Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
2522 questions Voir tout
Question close
Power on problem, could it be logic board?
Hello. I hope someone can please point me in the right direction.
I have an iphone 5 that was dropped on the sidewalk. The screen didnt break but the phone is dead. There are no lights or activity on the phone at all. If I plug it in to a charger, the phone just heats up and gets incredibly hot. Burning hot. I've tried plugging it into a computer with the home button held down - nothing. I've tried replacing the screen - nothing.
Does anyone think this might be a logic board issue? If you have any other ideas I would really love to hear them.
Thank you so much!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
It could be the logic board, but your description sounds like the power from the charger either isn't reaching the battery, or the battery can't accept the power. In both cases, the charge applied through the Lightning connector has to go somewhere, so it's dissipated as heat.
I would check to see that the drop didn't knock one or more connections loose. The connections that I think might result in these symptoms are:
  • the connection between the Lightning Connector module (also includes the headphone jack) and the logic board
  • the connection between the battery and the logic board
  • the connection between the power button/audio control cable and the logic board
iPhone 5 Lightning Connector and Headphone Jack Replacement
iPhone 5 Dock Connector and Headphone Jack
iPhone 5 Battery Replacement
iPhone 5 Replacement Battery
iPhone 5 Audio Control and Power Button Cable Replacement
Check these three connections, and replace any cables/modules that appear to be damaged. If a cable looks torn, or a connector or board is cracked, that's a strong candidate for replacement. Since you're inside the phone anyway, this is a good opportunity to swap out the original battery if you've been getting reduced charge life.
Image iPhone 5 Battery
Produit
iPhone 5 Battery
$29.99
Image iPhone 5 Lightning Connector and Headphone Jack
Produit
$19.99
Image iPhone 5 Audio Control and Power Button Cable
Produit
Image iPhone 5 Batterie
Tutoriel
Comment remplacer la batterie de votre iPhone 5
Difficulté :
Modérée
15 minutes - 1 hour
Image iPhone 5 Connecteur de charge Lightning et prise jack
Tutoriel
Remplacement du connecteur de charge Lightning et prise jack de l'iPhone 5
Difficulté :
Modérée
1 - 2 hours
Image iPhone 5 Nappe pour boutons de volume et de marche
Tutoriel
Remplacement de la nappe pour boutons de volume et de marche de l'iPhone 5
Difficulté :
Difficile
45 minutes - 3 hours
Indice 1
2 commentaires:
Thank you so much!!! That is really really helpful information. Thank you.
par
As my Fijian friends say, 'na wari' (no worries). Please post back and let us know what results from your experiments.
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 75
