PowerBook Won't Read Hard Drives!
Howdy everyone! I just purchased a little 12" PowerBook, and I was told that the Logic Board was broken, though the specifics were not mentioned. Well, it seems that the logic board works with the exception that the poor machine won't recognize internal hard drives. I think it could be the port on the logic board that's broken, but does anyone have any other suggestions? Is this a common problem with the 867MHz PowerBooks?
I know someone who's a computer engineer and he can work on broken logic boards, but what d'you all think? Is there anything I can do before I resort to that?
Thanks so much!
Sincerely,
Tommy
2 commentaires
So, I received the hard drive cable in the mail, and the logic board definitely seems to be the broken component. I'll have a friend of mine look at the connector on the board, and maybe I can replace it! Thanks for all your help!
par TommyJames337
anything new about this topic?? i have a 12" with a similar issue - mine doesn'tshow anything from the harddrive, but it tries to boot from it. you can hear is spinning and accessing - but it doesn't recognize the drive. in my case - the hdd is definately ok, the cable looks fine. i've used google and found many others had this issue too - but none posted a fix for that.
par markus weiher
