Aller au contenu principal
Ipad Mini 7,9" avec 16,32 ou 64 Go de stockage.
Questions au sujet de 671 Voir tout
Question close
potential problems by soldering the ic chip incorrectly?
Hi
is there any potential pronlems if I solder my own ic chip to a new digitiser? Would it blow anything if a couple of contacts were touching? Or would it simply not work?
Would like to practice this, but not at the expense of someones ipad when i repair it.
would be handy to do, as im fed up of these cheap ones which flicker everytime I lay it flat, and have to cover it in tape.
Thanks
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Réponse la plus utile
Most likely worst case scenario: dead device.
Update
If you don't do it right, you could get the power leads or voltage to where they don't belong. Hence possibility of a dead device is strong.
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
Is that fact or just a guess? Just that I would think as the connections would only ne sending signals, then I would imagine the digitiser would go a bit loopy as if the flex cable was pinched? But that's just a guess. Wonder if anyone has actually done it wrong? I know all the local repair shops in this area don't solder the parts.
par
par
Ok, I'm not really experienced at soldering, but practice makes perfect.
wonder if there's some sort of schematic for that connection?
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 101
