Is it possible to change the flash if it stops working?
Is it possible to change the flash if it stops working or if it will no longer will pop up?
Lauren, first I would check this page. follow the troubleshooting for the flash issues.
There is a tiny micro switch in the Hot Shoe (flash attachment on the top). I have seen where it will get stuck in the down position. Therefore the camera thinks it has an external flash on top. Use a straight pin or needle to pull the switch back up.
Make sure you have a good strong battery. I have had to clean the grooves under and around the flash with a cutip and toothpick using minimal alcohol
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 708
