Hey Tom,
I just did my first iPhone 6 LCD replacement, and I think I also broke the vinger print function.
How do I prevent this from happening in the future ? What action is the most delicate to perform that could damage the fingerprint function ?
Could it be that this happend when i was peeling off the home button connector that is attached to the LCD shield ? ( Like you can see in step 32 Remplacement du panneau avant de l'iPhone 6 Plus )
Or witch step is the most dangeres or delicate ?
Those from step 23 to 29 ?
I would really like to know how I prevent this kind off situations in the future.
I would really appreciate it, if you would look trew these steps and could help me preventing to do any damage at all.
If there went something wrong i think it would be by performing step 32, I was really careful with it but the connector wouldn't come lose off the LCD, think I will be using my opener in the future to loosen the adhesive with some heat.
Thank you for considering to answer this.
Best regards Koen
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
10 commentaires
DON'T MESS WITH TOUCH ID SENSOR, My LCD cracked on my iPhone 6, so i bought a iCloud locked iPhone 6 on Craigslist and swapped the whole LCD home button and all, the Touch ID stopped working so i restored and phone got bricked. Turns out that each Touch ID sensor is unique to the iPhone and is linked to the serial number of that iPhone. Thankfully Apple swapped the phone under warranty.
par Refat Bhuiyan
Out iPhone 6 got errand the Touch ID stopped working. Apple replaced the Touch ID and fixed the issue. So the Touch ID sensor can be replaced. But there must be a trick to it. Apple doesn't charge much at all for the iPhone 6. Not sure about 5S.
par armand
@ armand the 'trick' is that apple programed a new touch id sensor to your specific iPhone. Also Neil wanted to change the color and Apple doesn't do color changes. Apple can replace the touch id home button, but do not mess with it and don't let anyone else beside Apple store mess with it.
par Refat Bhuiyan
Aoa refat
I purchased iphone6 and while updating to ios 8.4 it got stucked in recovery mode and my phone us brick now..i came to know that my phone display was already replaced and now original touch id is not available..can apple replace me with new touch id button?
par malik
Befat
Plz reaply me at my email
Billzmalik01@gmail.com
par malik
Voir 5 commentaires en plus
