Can't use boot modifiers
Here's a strange one for you guys.
I just picked up a used MacBook that I'm working on refurbishing for sale. The trackpad needed to be replaced, so I took care of that. I also upgraded the hard drive and RAM (came with 2 GB upgraded to 4 GB). After all that was done, I went to format the HD and install a fresh copy of Mavericks. Strangely enough though, my usual method of holding down the option key at startup so I can select my Mavericks USB install drive did not work. When I tried, it just booted up normally. So I changed the startup disk in System Preferences and did the format and install figuring that maybe the problem would resolve itself with a fresh copy of OS X. Unfortunately it did not. I tried to reset the PRAM, and discovered that I am not able to do that either. In fact, when resetting the PRAM, it boots into recovery mode, so it is at least recognizing that I have the R key held down.
At this point, I started to explore the idea that the keyboard could be faulty. I first tried to use an external keyboard and saw no changes in behavior. Then I booted the machine and tested each key. No issues with any of the keys responding. So I don't believe that it's the keyboard.
Other troubleshooting that I have done:
- Checked to see if there was a firmware password set, There was not. I enabled a firmware password, rebooted, and removed it just to be sure that it was off.
- I tried installing the original RAM that came with the machine. No changes.
- I tried installing other RAM, both 1 and 2 GB SODIMM's, again, no luck.
So anyone have any suggestions? If it's not the keyboard, there isn't a firmware password, and it's not the RAM, what in the world could be causing this??
Thanks!
3 commentaires
I wanted to add that I reset the SMC just in the off chance that would have an effect. Although this did not solve the problem, it did confirm for me that the problem is not the keyboard, because when I reset the SMC the MagSafe adapter changed from amber to green.
par iGuys
Another small development...it does allow me to boot into safe mode by holding down the shift key. This should confirm that there is no firmware password, since if there was once enabled, I would not be able to boot to safe mode as per this Apple support document:
http://support.apple.com/kb/ht1352
par iGuys
This could be unrelated...or it could be the cause somehow...but I just figured out that one of the two USB ports on the machine is faulty. So perhaps there's something wrong with the USB Bus on the logic board that is preventing it from seeing the internal keyboard during the boot process? I tried again with an external keyboard plugged into the known good USB port, but that still did not work.
par iGuys
