bad earphones input and ethernet.
Hi, I cheked a lot of times with different earphones and the same thing: when I plug the earphones I hear weird sounds and only in 1 ear.
The speaker is just fine, so does the earphones - it's a problem in the input.
I also got a problem with the ethernet input - I used the ethernet cable using my lapop and everything works, but when I connect it to the iMac it doesn't work.
All the other connectors are working (I have no idea about the FireWire)
Also when I first bought the iMac I used ethernet and also the earphones input and they both worked well.
Une réponse ! View the answer J'ai le même problème
Commentaires:
Need more info than a generic ID that covers 19 models over 5 years.
par
iMac mid 2011 EMC 2429
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 réponse
Solution retenue
Of course the earphones work as expected in other devices?
If the cable end is still good (tang there and not weak) it may be the port is damaged. Generally these ports are not designed to be used often so frequent and rough handling may damage them.
Logic board soldering takes lots of practice and requires special tools. A local computer repair shop, or small electronics repair shop should be able to repair them if (after you examine them) they seem lose (there should be no movement of the port/connector).
A workaround for each may be dongles. USB Ethernet and audio adapters could substitute for dismantling and repair of the logic board.
If this answer is acceptable please remember to return and mark it accepted.
Cette réponse est utile ?
Ajoutez une réponse
Ishay Frenkel sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 67
