Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
La version Wi-Fi+ cellulaire de l'iPad Air d'Apple, numéro de modèle A1475. Disponible en gris sidéral ou argent, il emploie le processeur A7 personnalisé et est livré dans des configurations 16, 32, 64 et 128 Go.
Questions au sujet de 122 Voir tout
touch screen not working when I lay new screen down?
installed new digitizer, tested works good, but as soon as i lay the screen down, the touch stops working. help?
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
also, there are no tears or anything in the cables
par
Ajouter un commentaire
Le kit d'outils Essentiel
Les outils les plus utiles dans notre kit le plus compact.
J'achète
J'achète
3 solutions
Réponse la plus utile
If it's a copy screen you will no this as on the original the inside border bronze the copy's are sliver..
The copy's have a tendency to short out against the frame check this out could be the same ideasolution to phantom/ghost touches ipad air
Cette réponse a-t-elle été utile ?
Indice 1
Commentaires:
Wow con, you are seriously a genius. It hasn't worked yet, but I will try it now. This is the only answer that has made sense, and you have helped me in the past. Thanks
par
So it totally! Worked thanks so much...BUT, now the home button isnt working, and double checked the connection and tried another home button :/
par
Mmmmm try a home flex from a different vendor if that doesn't work then it could be s problem with the board
par
its so weird, both cables i think are fine and there is no apparent damage to the board. i also noticed if i push on one side of the screen/frame, its turns the phone on and off. ugh
par
Glad that helped
Have you tried two home button flexes and they arnt working?
Indice 0
Commentaires:
yes :/
im not sure what is going on
par
Check C6505. Worked for me.
Indice 0
Ajouter une réponse
Austin Harris sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 1,743
