Aller au contenu principal
Released Pre-Fall 1997, identified by model number RM318PA
Questions au sujet de 7 Voir tout
Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
Une réponse ! View the answer J'ai le même problème
Commentaires:
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
par
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
Hi Kathy,
Sometimes the on/off switch can get a bit loose and you might need to snap it back in place. See the guide linked below!
Oregon Scientific RM318PA Power Switch Replacement
Cette réponse est utile ?
Ajoutez une réponse
Kathy Rowley sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 220
