Processeur 1.4GHz ou 1.6GHz, SSD de 64 Go or 128 Go.
Questions au sujet de 152 Voir tout
screen dead need to transfer hard drive
I have an 11" macbook air, 4gb,128gb flash drive. The screen is dead and I want to get my stuff off the hard drive, any suggestions?
Une réponse ! View the answer J'ai le même problème
Commentaires:
Can you give us the last four digits of your serial number so we can correctly identify which model version you have.
par
Have you tried using an external monitor? If the GPU its not totally thrashed it could work.
par
I haven't tried anything. I believe the hard drive is fine, just the monitor doesn't work so I can't see anything. I have a macbook pro can I transfer in to that somehow?
par
No, you can't swap out the HD or SSD (depending on your air model) as they use a different connections. Again please give us the systems S/N so we can help you here.
par
I don't want to swap HD just copy any files or photos off of it. The S/N is
C02DM4A0DJDL. Thank you for your help!
par
Afficher 1 commentaire en plus
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Your best bet here is to take the SSD out of the system and place it into a case which is designed for the SSD. OWC offers such a case: Envoy - Portable, Bus-Powered USB 3.0 Storage. Then you can connect it to another Mac system to copy off your stuff. Here's the IFIXIT guide on removing the SSD MacBook Air 11" Late 2010 Solid-State Drive Replacement
The other option here is to setup your MacBook Air in Target mode but without a working display they will be tough and you'll need a Ethernet adapter.
If you have access to an external display via a Mini DisplayPort and can get it working you could try copying off via a USB thumb drive.
The last two options are more costly if you don't have the needed hardware already.
Cette réponse est utile ?
Score 1
Commentaires:
Or if external video works you could boot the MBA and Target the MBP then transfer data.
par
Ajoutez une réponse
CLM sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 370
