Aller au contenu principal
Modèle A1502 / processeur dual-core Intel Core i7 2,6 GHz (Turbo Boost jusqu'à 3,1 GHz) ou 2,8 GHz (Turbo Boost jusqu'à 3,3 GHz) avec 4 Mo de cache L3 partagé.
494 questions Voir tout
Temperature of mac vs fan rpm
The fan on my mid 2014 macbook pro retina always seems to be running at around 1300 or so rpm. However, it doesn't seem to go higher even when the system temperature increases.
For example it was once operating at around 71c with only around 1295-1306rpm.
Is this normal operation?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
You raise a good question here on what is the max RPM this systems fan runs upto.
par
Ajouter un commentaire
1 Réponse
Solution retenue
The fans can run at 2,200 RMP or more, but it's best not to fool with them manually if at all possible.
If you want to investigate the state of your hardware, connect the MacBook Pro to a charger and use Apple Hardware Test. In case of heat issues, or to generate more heat run the test 2 or 3x in succession.
After starting into Apple Hardware Test, choose your language, mark the option to run an extended test and start the test. If at the end of the test you see an error, run it down.
If this answer is acceptable please remember to return and mark it accepted.
Indice 3
1 commentaire:
Agreed! + Using software to over-ride the fan/s only shortens the life of your system. What is important is using the correct hardware and if needed adapter cables so the built-in temperature management system is able to effectively manage the heat generation in real time.
par
Ajouter une réponse
Will sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5,173
