MacBook air wont open its stuck on loading on user
My Macbook Air 11" does not open. It just keep on loading after I click on the user name.
Kindly help what to do?
Try this.. Turn it off, then press the on button and right away prss and bold the option key. The pm you should see recovery partition come up. Go into it and once it boots up open disk utility and try to repair the disk permissions and also repair disk.
didn't work for me... it's stuck on the screen with the apple and the loading bar... it looks like it'll almost finish loading, then it just stays on the last bit and won't load all the way... :(
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 20,688
2 commentaires
Yolo, I have tried your suggestion but it says it cant repair the disk & back as many files and reformat the disk. Can you help me again on this? Thank you so much.
par apolsune
Sounds like your ssd may be failing but try this:
Turn it off then when you press the on button quickly press and hold the [option key+ S]
It will go into a black screen and some wrtiting will come up. Once the writing stops loading type
"fsck -fy" - no quotation marks and press enter. Hopefully this will repair it. It'll run through a process and if all is good it'll say that it was repaired. You can then type "restart" and press enter. If it doesn't repair it, sorry but you may have to format your drive and try to reinstall.
par Alfy
