Errors in the range of 4000-4016 have to do with issues involving the USB connection or security software.
Check USB connections
If there’s an issue with the USB port, cable, dock, or hub, or if the device becomes disconnected during restore, try troubleshooting the USB connection, then troubleshooting your security software.
To narrow down the issue, you can also change up your hardware:
Use another USB cable.
Plug your cable into a different USB port on your computer.
Try a different dock connector (or no dock).
Add (or remove) a USB hub between your device and computer.
Connect your computer directly to your Internet source, with no routers, hubs, or switches.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
