Not working will not power up
I have the Toshiba C55t-A5218.
I couldnt get windows to come up, but later did.
However when the laptop was doing a restart, it died and now it wont power up at all (with adapter or battery.
Any suggestions? The power adapter is producing 19 volts. I have also completed an ohm test on the power adapter cable in the laptop, all is well there. It wont power up with the battery plugged in. But I am uncertain if the battery is charged.
Also removed the memory and still same results. Please help, or I have a boat anchor.
6 commentaires
Toshiba offers a nice support page: SATELLITE C55T-A5218 SUPPORT
par Dan
I tried another power adapter and it worked perfectly. So i ordered a new one and was even able to install WIN 10 on it and sold it to a person.
par Darren
Hey thats GRAET !
The laptop is working aging :)
thank u Darren !
par Tsvika Damri
I have no power at all. The laptop will not boot, nor does any indicator LED come on showing power is present. There is a good DC voltage at the power cord. The 3V battery cell is good, but I replaced it anyway in case I was only reading a surface charge. I disassembled the laptop and checked the main board fuse; it was good.
I have installed a new 10.8V main battery with no luck. I did remove the power cord and battery, held the power button down for 45 seconds, and then tried each of the power supplies; again with no luck. I suspect a bad power circuit on the motherboard. If that is true then the computer has turned into a brick.
par Don McC
@Tsvika Damri Thank you
par Darren
Afficher 1 commentaire en plus
