How can I fix broken camera cable
While I am trying to remove the optical drive from my MBP with following the instructions of the iFixit, I could not remove the Camera cable socket and I broke off the cable from the socket. You can see the current situation of the cable and socket from the pictures I uploaded:
http://imageshack.com/a/img537/6886/ZRZd...
http://imageshack.com/a/img661/914/sfzmP...
For checking my system after this accident, I run my laptop and as I expected camera did not work. But everything except camera was working well.
So what's the way of fix this problem?
By the way, I just realized that actually I was able to remove the Optical Drive without removing that lovely socket!..
Thanks!
2 commentaires
Hello Yusuf,
Did you find a way to solve your problem?
Regards
par Luiz Suraty
Nope, not yet because of my unusual busy period i could not focus on this problem...
Also I am kind of hesitating about fixing this tiny problem with a huge technical solution as @Dan mentioned above.
I don't want to take the display off and its almost whole components, at least i think i am not able to make it possible in this way... If there is no other option, i guess i will have to go to some service/technician in a time.
par Yusuf
