Aller au contenu principal
Écran de 7,9 pouces / Modèle A1432 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012/ avec 16, 32 ou 64 Go de capacité
220 questions Voir tout
Yellow plastic on Connectors?
Could someone explain to me exactly what i am supposed to do with these yellow plastic pieces on this glass replacement?
Do i take them off???? Why are they here? they are confusing me....
What to do with yellow tapes
http://s21.postimg.org/rsdmsbjon/image.j...
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
It is kapton tape and is there as an insulator for the exposed electronics. If you remove it you will need to replace it with the black tape on the original glass or the digitizer and home button will not function properly when you put it back together.
Indice 1
3 commentaires:
ok so i leave it all on? dont touch any of it???
par
Yes that is Correct.
par
and what is the name of the black tar-like glue under the glass that comes already inside of the ipad?
is there something similar that i could buy at like a home depot?
par
leave the kapton tape alone, as Brian suggests.
I can see that your replacement digitizer already has the black adhesive sticker pre-installed. After testing, when you're ready to do your final seal, pull the plastic covering off your black adhesive sticker all the way around your screen. Don't forget to pull the plastic off the inside of the digitizer as well. Seal your new screen, then gently heat the edges of the mini to activate the adhesive and create a stronger bond.
jessa
Indice 0
1 commentaire:
Thank you jessa. and yes i plan on doing that, but i am in need or the black tar-like substance, that is already inside the ipad, the really sticky black stuff.. i would like the name of it, because i would like to buy some, even for another porject
what is the black tar stuff called?
par
Ajouter une réponse
dovedescent7 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 140
