My 2009 Ford Escape windshield washer front and back stopped working at the same time a few months ago. I haven't had a chance to look at it until last night. The reservoir is filled to the max line. There hasn't been any leakage. I tested the pumps by having the hood open, windows down, and ran the motors. I know they work because they are on the same circuit as the wipers. The wipers work, but no fluid in front or back come out? Would this be a clogged pump, reservoir dirty, or clogged lines? Thanks.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
7 commentaires
Brian, did you find out what was causing this? I have the exact same problem. David
Brian, did you get a resolution to your problem? I'm having the same issue. Doesn't seem right that it could be the pump, since it appears there is a separate pump for front and rear.
Which pump did they replace since both front and back were not working? Or did they have to replace both??? Just curious, mine Escape is doing the same thing.
having the same problem went to local AAA car service, they first asked to sign for $99 diagnostic labor. Then after they checked waved the charge since the problem with no spraying in front and back was solved in a min by untangeling the line leading from the reservoir to the nozzles. Solved.
Before I went to this service I have excuded the bad fuse, since the windshield wipers (front & back were working), also that the pump is working by opening the window and the engine cover and listening whether the pum is working, i.e., producing a noise. So talking to the mehsnic I indicated that he needs to check for cloging, or else with the line, and he focused and found the cause very quick.
1. Did you verify the pumps are working? If so check the hoses for kinks and check the nozzles for clogs. Use a pin or needle to clean the nozzles if they are clogged.
2. Do you have voltage to the pumps? You can check with a volt/amp meter.
3. Have you verified that the fuse(s) is/are not blown, If so replace and find out why the fuse blew. Look for chaffed wires. Pay close attention to wires under clamps. Sometimes the clamps can rub the insulation and cause a short.
Sometimes a fuse will blow for not apparent reason other than it's just old or all the stars have aligned perfectly to cause it to blow. I have had that happen on two occasions.
10 commentaires:
My pump was gone. Replaced it and now both front and back work. Fuses were good. Thanks for the other suggestions. Sandra
I'm in the same boat I can't figgure it out. Put a new pump in still didn't work. All fuses and relays are good. I don't have power goin to the pump for some reason
Had this on 2010 Escape. SOLVED! My rear wiper motor was fused, draining my battery. I pulled the fuse. Washer fluid pump still working… A week later I removed the bad rear wiper motor ( on the glass of the hatch), getting ready to replace it the next day. After I unplugged the power to the rear motor, MY WIPER FLUID PUMP WOULD NOT WORK. Today I just now put a new motor back in and WIPER FLUID PUMP WORKS AGAIN.
My conclusion. Nothing wrong with pump, but ground for circut must go through the back motor, ( still worked with rear wiper motor fuse out).
3 commentaires:
I just discovered this after replacing the pump. My rear motor was draining battery also. I did this in summer and didn't notice the water not spraying. It was more important in the winter. After pump replacement, I tried reconnecting rear washer. It worked. I couldn't replace the rear motor because it requires a puller tool.
So now I'm searching for a way to jump the wires for the rear motor. I figure it is just not receiving the signal in front.
I followed the instructions on locating the fusebox below from Anne. It is passenger side under a cover. I unplugged 43 (Rear Wiper Logic and Heated Seats), 10 amp. Replugged rear wiper and front wipers still worked, spray and wipe.
Thanks! This was what helped me here. I had disconnected the connector for the back wiper because it had stopped working and I wanted to look further into it but got stopped by the need for a puller tool. Shortly thereafter I noticed that the wiper fluid had stopped working but didn't connect the two until this comment. Went back and connected the rear wiper connector again and all is well (except the rear wiper still, but that can wait)
09 Tribute, both wipers work but no washer on front or back. The pump is bi directional and is fused thru the front windshield wiper fuse. If the wipers work but the pump doesn't, ether the pump is bad or the connection on the pump is corroded. Loosen the inner fender well panel, disconnect the pump and check for power in the connector when the washer button pi pressed. If you have power, clean the connections and reconnect. Does it work? If not, replace the pump.
2 commentaires:
I checked the pump. it is good. And I checked the fuses they are good too. there are no voltage at the connector when I switched on the pump.Now I doubt the switch has gone.
My symptom, front windshield washer works, rear one does not.
Ford uses a common pump for both front and rear washers. There are 2 hoses coming out of the pump, one to the front washers, the other to the back washers.
Front washer - 12 Volt powers the pump to pump water to front washer.
Rear washer - reverse the voltage to the pump, reversing pump direction to pump water to the rear washer nozzle.
I have removed the pump from inside the fender well. When I connect 12 Volts to it, pumps water out one discharge port. When I reverse the voltage (and therefore reverse pump direction) it pumps water out the other discharge port. When I put the pump back in, I can operate both washers supplying external 12 Volts and reversing the connection.
My problem is the pump operates to the front windshield, however, does not operate the rear washer. It does not operate, there is no voltage present and no clogs in the water line. I can blow air through the line and it bubbles in the washer tank.
I have changed the pump, the turn signal switch that activates the front/rear pump and the rear wiper. Fuses are good for both front and rear wipers.
Obviously a wiring problem since I have changed every component in the system.
Where to start looking?
Update (03/20/23)
I got into the Ford wiring and am still frustrated.
2012 Escape, front washer works, rear washer does not.
There is only 1 pump on the washer reservoir inside the front passenger side fender.
When I operate the washer on the front, the pump operates and I can hear it while spraying water.
When I operate the washer on the rear, the pump does not operate and I cannot hear it.
Ford was innovative when they wired it.
Connect 12 VDC to the pump one way and it pumps fluid to the front, reverse the 12 VDC power at the pump, the pump runs backwards and pumps fluid to the rear washer. I proved this using a 12VDC supply connected to the washer pump.
Reverse the power connection and fluid goes the other way to the other window.
I have replaced the washer pump with no change to the symptom.
I also replaced the wiper switch on the steering column.
It appears there are relays in both the front windshield wiper motor and rear wiper motor that perform the magic of reversing the voltage at the actual washer pump.
I have now replaced both the front wiper motor and rear wiper motor twice and I still have the same problem.
Must be a wiring issue, although I cannot find the wire return from the rear wiper motor that will operates the pump in reverse to squirt water to the back washer nozzle.
Still frustrated and the back squirt nozzle does not spray water.
4 commentaires:
Brian, you need to use a 12 volt test light before replacing parts. It could be something as simple as no ground to the circuit that runs pump in the direction to pump out the rear outlet. Obviously by hot wiring the pump in both directions proves the motor is ok. Trouble shoot the wires at pump. One direction will give power and ground to run one way, the rear pump switch will reverse polarity running the other direction. Simply figure out what you have and what you don’t at the pump connection, then figure out why.
Brian, did you ever figure this out?? I have almost the exact same problem. 2013 Ford Flex. Front sprayer not working, rear works. Replaced MultiSwitch. Put cheap washer pump from Amazon into the harness and same issue. Front washer will not activate the pump. Tested the NEW pump in a bucket of water like you did... hooked to 12v battery,, water exited one side. Reversed polarity... water exited BOTH sides. That made no sense. Took a voltmeter to the harness.. got 12 V when activating rear washer. Switched probe and then got 12 V on other terminal when activating front washer pump. Should be working, but got no power to the cheap pump for the front washer. My only guess is that since the voltmeter was neg grounded on the frame, there might be a break in the ground in the harness somewhere. Otherwise, why didn't the cheap pump come on for the front sprayer (granted it might have come on for front and back at the same time, but then I'd know it was a bad pump too.). So confused.
Buying a better pump at the parts store tomorrow. Will test first in the bucket of water to see if it pumps each side separately when polarity reversed. If that passes, then I'll hook it in the harness and see if it works. If the front still won't work, then it has to be the ground in the harness somewhere, but only if there is a ground for the front and a separate ground for the rear washer. Otherwise the rear shouldn't have worked either I'm guessing. I'm so confused at this point. If that still doesn't fix it, I'll pull the old pump out of the car, and test IT in the bucket of water. If it works on direct 12 V and reverses properly... then it works and it HAS to be somewhere in the harness, or somewhere AFTER the multiswitch. Nothing else makes sense. I'll update tomorrow after I test the new(er) pump on the harness and bucket test.
UPDATE: purchased brand new pump from Ford. Same problem, no action on the front sprayer when button pushed. Used voltmeter again, but used + - on the terminals of the harness (did not use frame for ground). 12V when activating rear washer again... 0v on the front. Switched polarity of terminals, 0v on the front still. Looks like there is no ground coming through the harness for whatever reason. Above my pay grade, going into the shop. Will update if they ever figure it out.
2 commentaires:
Omg I can answer this. I have a 2009 escape. It’s on passenger side of car. To the left of your legs while you’re sitting there. On the console in center near floor. Take off that cover. Then u need to take off fuse box cover. Squeeze top and bottom of actual fusebox together by pressing tab on top and bottom and it will pop off.
2009 Escape: Front and rear washers failed at the same time. . .found main water delivery tube broken at the right side hood hinge and a pool of water under the broken end. I hope the tube can be spliced. . .don't relish the thought of having to thread in a whole new tube.
7 commentaires
par David Partager
par davetodd5 Partager
Hey Brian,
I'm glad to hear it was a simple pump to replace.
PT
par Paul Partager
par jbirk Partager
par vik1919 Partager
Voir 2 commentaires en plus
