Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Roomba 650 est un aspirateur robot de quatrième génération sorti par iRobot en août 2012. Cet appareil fonctionne en mains libres et est programmé pour nettoyer nos maisons. Avec très peu de manipulations manuelles nécessaires, ce robot a révolutionné le nettoyage domestique.
How do I replace the side brush motor on my Roomba 650?
The side brush on my Roomba 650 no longer spins, but drags along the floor with the Roomba. I think the motor could be broken, but am not sure how to fix it.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Roomba 650 is not bad, i mean its cleaning performance is superior. But i think its time to change your Roomba 650. You may choose Roomba 880, which is highly durable. I have one Roomba 880 model. I choose it from this site http://smarthouserobots.com/product_cate... I hope this article will help you
par
Ajouter un commentaire
2 Réponses
Solution retenue
The side brush is most likely not functioning anymore either because debris is preventing it from spinning or the motor has died. Check out this guide on how to replace the motor or see what's wrong. You may find that the motor has died and you need to purchase a new one.
Indice 2
There are several others who are having the same issue. If you remove the motor apply 9 or 10 volts DC for a moment to see if it rotates? Mine did. So, it's not the motor. To check it out remove the (4) screws from the bottom that will remove the bottom cover and allow you to see the side brush assemblely. (2) screws remove the side brush motor. You can check to see if it will spin freely by gently rotating the grush. More than likely it is a sensor issue, dirty or something.
Without a schematic I have no Idea how it gets it power to spin.
If you stumble on any info please let me know.
Rick
nealre990@gmail.com
Indice 0
Ajouter une réponse
Charles Ward sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 8,332
