phone is coming on and staying on "BLU" ,how to fix it?
my phone is coming on and the screen is staying on the word "BLU" and not coming on fully
i'm having the same problem.. but when factory reset and restart it.. the problem do not change :-(
i tried that method but it still didnt work..what other options do i have or what do you recommend?
Did u wipe the catch partition in the recovery? If not then try that. And if still that didnt help out. Then u may need to flash the phone. Look in here for answers on how to http://forum.xda-developers.com/android/...
i did it and phone not working
you have to boot into recovery and wipe data or factory reset..
remove the battery and wait for some seconds then insert the battery again
hold volume down and power button together until u see a recovery menu, then choose wipe data/factory reset us volume down/up to navigate .. then restart when done..
WARNING!personal data Like SMS/MMS/Contacts/Apps/call history .... will be gone for good if you need those then consider taking the phone a pro for backup..
Media such us pictures/videos/musics will not be affected
I tried that but the same thing is still happening!!!!!!
i tried that but the same thing is happening
Did your phone ever started working properly. Again. Guys??
its the same thing happening ugggggggggh
can you help me how to update the software
Have your tried booting in safe mode? A safe mode can help you to diagnise and uninstall the culprit app causing your mobile to stuck on boot screen. Safe mode can also help you to detect if there is any hardware or software issue on the mobile.
This will boot your Mobile in safe mode. Unistall any recent install app which you think migh cause the error.
Follow the detailed guide here: Android Safe Mode, What is Safe Mode? How to Use it to diagnose the Android problem.
Thanks for the answer @somnio360. The guide was helpful and worked for me
I had the Blu 4.0 star, and the brand itself is pretty bad :/ its a cheap brand, and I had that problem, and exchanged it, and the problem came up again :/ factory reset worked for a while, but it is a problem that will happened again and again. I would suggest a new phone.
use volume down/up to navigate and power button to select.
Did you get your phone fixed?? If so what did you do?? Im having the same issues with my Blu 7.0
Sim kit not in stole
I had the same problem and i had to send it in. no reset would work. good luck
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 3,035
1 commentaire
How to solve this problem
par El Haj Omar Lwambwa
