Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La tablette tactile Linsay modèle F-7HD2CORE offre des fonctionnalités de lecture, de photographie et d'accès à Internet.
Can the Linsay Tablet's screen be replaced or repaired?
I dropped my tablet on the ground today and the screen smashed as a result. Is there a way to repair or replace the broken screen? My tablet's model is F-7HD2CORE.
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
Model f7uhd is the model numbers
par
Ajouter un commentaire
2 Réponses
Solution retenue
A smashed screen cannot be repaired, but it can be easily replaced. Replacement screens can be purchased here.
For more information, see our troubleshooting page.
Indice 3
Another word of advise regarding this particular repair. Before you order your replacement screen or the digitizer make sure you got the right dimensions, the correct orientation of the ribbon cable and the position of the view-port camera window. (Left, Center, Right top of screen).
Another helpful hint; Make sure the problem is the LCD screen and not the digitizer. There are two layers to this, Digitizer screen has a clear sticky plastic glued to a glass (top layer), if the tablet is not responding to finger touches Digitizer is the problem. However;
If the LCD screen has garbled images, lines or liquid stains then is the LCD screen is your problem.
In my case it was both. I ordered my replacements from ACTABLET.COM
Indice 0
Ajouter une réponse
Lindsay Byrnes sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 2,933
