Kenmore Ice Maker M1 SA8868 won't eject ice, control arm doesn't move
I have a Kenmore Ice Maker M1 SA8868 in my freezer. It previously worked fine for years. I moved to a home without a water hookup, so I stopped using it. I just moved back to a home WITH a hookup, and now the ice maker work right.
It won't eject the cubes it makes, the control arm doesn't move (auto or manual), and manually initiated ejection [cycle] of ice stalls when ejectors hit the cubes, but they eject about an hour later. This likely means that the arm didn't move automatically earlier either (I can't sit and watch it all day). Then water refill not initiated every time.
I don't think anything is working automatically. Initial water fill was after manual turn of the dial to initiate first cycle. After 12 hours, no functions. I initiated manual cycle, ejectors got stuck on ice. An hour later the cubes finally ejected, but control arm didn't appear to move at any point. I cycled manually again, water finally refilled. Arm still apparently unmoving.
I have already replaced the Automatic Water Supply Valve (AWSV) that feeds the icemaker to solve a previous issue, and I tested with a known GOOD icemaker successfully. So I know the problems are within the existing icemaker.
2 commentaires
Freezer temp is 18-32 degrees on lowest setting and DOES make ice. Ejection cycle and refill is the issue. I have a replacement in-hand, but I would like to return it and keep the ~$50, if the original unit can be repaired for a reasonable amount.
par scottbernardis
Pictures of the exact unit HERE on alternate thread when I replaced the AWSV:
Kenmore Ice Maker M1 SA8868 drips gallons of water into catch box?
par scottbernardis
