Aller au contenu principal
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 questions Voir tout
still soft brakes after bleeding them
I changed my 1994 Ford Ranger rear brakes bleed 3 times and adjusted them still soft peddle (goes to floor) while driving please help what do I do next
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Assuming the bleeding procedure was done correctly, did you check for leaking lines, bad bleeder nipples or leaking wheel cylinder? If all of those are checking out, you need to consider a bad master brake cylinder.
Indice 1
2 commentaires:
OK ty has to be bad master cylinder again ty
par
Make sure if it has RABS you're bleeding the abs unit on the frame rail!
par
Did you try putting a piece of wood under the pedal while bleeding ,...? I've heard it was nessesary on that year Ranger
Indice 0
Ajouter une réponse
Jerry buddman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,329
