o First clean the surface of the disc with a soft lint-free cloth. You can use a gentle detergent (or rubbing alcohol) if there are some grease spots. Make sure there are no finger prints or dust particles. Don’t scrub too hard as you may do more harm than good this way.
o Now apply some toothpaste or polish on the scratched surface. It is best to start with a minimum amount of either, or else you will have your work really cut out trying to buff away the remainder.
o Now rub gently with a cloth moving from the center outwards.
If you did a good job, you will actually see the scratch diminishing, or if it was a faint one, it might just disappear.
The success with this method varies greatly. It is hit and miss. I have had an equal amount of successes and failures. Sometimes it works allowing you to even read data from that part, other times it is of no use at all.
IN case guide above can't help you or your CD is severely corrupted, visit next source:
https://discuss.howtogeek.com/t/how-to-r...
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
