Aller au contenu principal
The Samsung WB150F is a 14 megapixel camera with 18x optical zoom and Wi-Fi connectivity.
Questions au sujet de 14 Voir tout
Why won't my camera connect to my computer?
When I plug the USB cable into my camera and then into my computer, the computer is not recognizing that the camera is connected.
Répondre à cette question J'ai le même problème
Indice 9
1 commentaire
I have sent my NX300 back to Samsung 3 times Inc to Korea, all under warrenty no charges for postage, and they get it to work but not on my computer!
It continues to do what some others are describing. see chrismoss + gagajus.
Samsung have a problem with this setup and you should complain to them, ask for money back or replacement.
par
Ajouter un commentaire
8 Réponses
Réponse la plus utile
hello pls i need help for my Samsung wb30f camera ... i have upgraded firmware zip from download page and i dont have used I launcher for this purpose ..i extracted zip file from computer to micro sd card from my camera and put back to camera ..when i wake up the camera ....automaticaly firmware start to install .. after a few minutes ..it shuts down and that s all .. my camera is dead ..cannot boot nothing ...my laptop doesnt see anymore my camera ..but camera led indicator shows when is on charge red or yellow when is started nothing else works ....pls help ...what should i do to fix this ...here is my mail pls send me answer to :gajagus@gmail.com regards
Indice 1
The internal connectors on your micro USB wire may be broken, the easiest solution would be to use a new wire. Most cell phone charger wires are compatible.
Indice 0
Mine wouldn't connect to the PC via USB. Windows 7 said it had finished installing the drivers. Then the camera would try to connect, opening a dialog, and then immediately closing it, bouncing like a ping pong ball. Tried all the usual. Restarted PC, looked for drivers on Samsung website, nothing. Tried my usb on a different camera, cord worked on that one so I knew the cord was fine.
Check the menu settings in the camera itself. You may have to disable wireless sharing, or whatever that's called on yours. Once I disabled that in the camera, mine connected to the PC without fuss. Samsung WB35F camera. Windows 7 Pro 64-bit.
Indice 0
Photos I took today will not upload to my computer. This never happened before. What is wrong?
Indice 0
This message appear when turning on the camera.
Also, the computer can’t recognise the USB.
Please, what is the reason?
Indice 0
I cannot upload my photos from the Samsung WB200F.
Can anyone help me with the drivers I needed.
There are special photos of a funeral, that I like to upload to my computer (windows10)_
Thank for your help.
Indice 0
1 commentaire:
If you're storing them on a micro SD, pop it out and use a card reader. You may need an adapter
par
Issue: WiFi Digital camera cannot find my windows 8 PC on network.
Solution: Make sure to install the i-launcher software by Samsung. But before doing so make sure you disable your PC Antivirus (especially McaFee or Norton). Then attempt to search for your PC through digital camera make sure to connect to the same network your computer is connected to. It should find it & transfer the pics automatically its great!
AntiVirus: If you want to use your AntiVirus & WiFi digital camera you’ll need to follow the directions that pop up when you first install the Samsung software. It requires you add a specific program to get permission by Antivirus.
Indice 0
Start power on, but zoomer not working
Indice 0
Ajouter une réponse
Keith Albergaria sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 63
Total : 16,092
