Why won't the drill stop when I release the trigger?
The drill continues to operate even when I release the trigger.
La RIDGID R86034 est une perceuse à percussion au Lithium Ion fabriquée par RIDGID en 2012.
There are three possible cases that could cause this problem. First, you just have a sticky trigger or something lodged into the trigger mechanism. This is a relatively easy fix and just requires cleaning the trigger. If necessary you can open up the casing and remove any debris surrounding the trigger. If that doesn't help it could be that your trigger mechanism is broken and needs replacing. If that doesn't help then it means that your wiring is bad. Instead of using friction brakes, drivers reverse their polarity in their engines in order to slow themselves down. There is probably something wrong with how the wire are connected and you should rewire your driver to match that of the wiring diagram of the parts list which can be found on the main device page. Your question can also be answered on the RIDGID X4 18V Lithium-Ion Impact Driver Troubleshooting page.
Commentaires:
i do believe a drill can't reconfigure its wiering all by its sell so why would you say to rewire it.
par Julio Mayer
It could have been manufactured wrong, or a some failure occurred under operation such as short or open (wires start to touch or disconnect when they shouldn't under the original design).
par Nathan Hoyt
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 116
Total : 4,870
