Aller au contenu principal
The Philips model GC8220/02 is a pressurized steam generator that uses a 1.4-liter detachable water tank for ironing and steaming fabrics.
17 questions Voir tout
Why my steam iron can't get steam come out
The steam iron, I get the problem is steam don't came out...when I press the pressure button on the handle ,steam don't came out n the water still get boilling no steam out. How can I fix it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
Ajouter un commentaire
3 Réponses
Solution retenue
Hello,
I would try using a 50/50 mixture of distilled water and vinegar. I use this mixture to clean my coffee pot and steam mop. 90% of the time it works everytime!
Indice 3
Hello!
I just find some good web page. This problem is related to electronic, pump power supply.
https://lieven.kks36.be/2016/06/11/phili...
I hope it will help You.
Best regards!
Marin
Indice 0
2 commentaires:
How can I solve my steam generator problems, it do trip off if you pressed pressure bottom on the handle and steam doesn't come even after I cleaned it with 50/50 with white vinegar. Bello
par
Brilliant thank you. It's working now. 😁👏
par
Try opening cap where the water is topped up. If it starts to steam then, on my Philips Azur, there are two tiny pinholes in the cap which were blocked. A poke with a pin was enough to sort the problem. They allow air to enter as it steams, otherwise a vacum would occur and stop the water flowing.
Indice 0
Ajouter une réponse
phongtu008 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 55
30 derniers jours : 284
Total : 68,998
