Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
How to decide whether to replace LCD screen digitizer or just LCD
My phone (Xiaomi Mi3) fell down and now the touch is not working. I can see the images and display is fine. There is no crack on the front glass panel , excpet for a small crack at the top left corner. But I can see a crack in the inside screen. So could you please tell me as to whether I will have to replace the entire touchscreen digitizer assembly or just the LCD screen ? And could you please explain the difference between the two ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 9
1 commentaire
My mob cracked but touch is working.
display is dim and not clear.... Repair possible or i have to change the whole display
par
Ajouter un commentaire
1 Réponse
Solution retenue
A touch screen display is usually made with three main parts. The protective glass sheet, the digitizer sheet, and the LCD. The digitizer is a thin transparent sheet that is adhered to the protective glass sheet with a transparent conductive adhesive. The digitizer is the only part of the display assembly that is responsible for sensing touch. Since the human touch is conductive it allows the screen to sense the location you touch. The LCD is only responsible for displaying the image on the screen. If the screen is not responding to touch then usually the digitizer is damaged or faulty. Usually a damaged or cracked LCD will display a distorted image or no image at all. So if the phone displays a good image but does not respond to touch then you may have the option of only replacing the digitizer. It's not as easy of a repair as replacing the whole display but is cheaper. A new digitizer part already has the digitizer sheet adhered to a protective sheet of glass. If a person can remove the faulty digitizer from the phone without damaging the LCD then it is surely more cost effective repair. Some displays have the digitizer fused to the LCD which makes it hard not to damage the LCD if trying to remove the digitizer. If that is the case with your phone's display it is a lot easier to just replace the whole display. Hope this information is helpful.
Indice 16
2 commentaires:
Hi, My Mi A1 is cracked but the touch still fine. what should i do? which part i need to replace?
par
Same with me Nur Muhammad. I have a Xiaomi Redmi 6 pro. The display and touch are working absolutely fine even from the edges. I think the protective glass sheet on the top (as you mentioned) is a little bit cracked from the top left corner of the screen. What should I get change? Can I just get change the protective glass sheet? Is the digitizer fixed with the protective glass sheet for which I need to get both changed (protective glass sheet and digitizer)? Or the whole touch screen assembly?
par
Ajouter une réponse
vinayraghunath1992 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 25
30 derniers jours : 122
Total : 30,278
