No sound. Speaker wire disconected.
I recently had to open up my Unibody A1342 due to water spillage.
As I was following your teardown, at step 10 I seemed to miss something. Whilst trying to gently pop off the speaker wire connector I must have used too much force and it just snapped off. I cannot see any way to simply click it back in, does it need soldering? There doesn't seem to be much metal to solder together, is there another option? Would hot glue work?
Update
You can see the damage here
And here.
I have since seen other instructions of what I should have done, gently prise the connector away. However, now that the damage is done is there anything i can do. I don't have any experiece with soldering.
Any advice greatly appreciated.
Thanks all.
4 commentaires
Sai G, post some images of your connector and the damage with your question. Using glue for a lasting repair is usually not an option.
par oldturkey03
Thanks for reply oldturkey03
I will post a photo as an answer as i can't see a way to do it here.
par Simon G
Use this guide to add images to an existing question Ajout d'images à une question existante
par oldturkey03
Got it
par Simon G
