How to remove ignition switch for repair?
I have a Chevrolet Silvadedo 1500 1992. I want to change the ignition switch.
These are instructions for the 2000 model but will probably serve you:
Ignition Switch Replacement - On Vehicle
Removal Procedure
Caution: This vehicle is equipped with a Supplemental Inflatable Restraint (SIR) System. Failure to follow the correct procedure could cause the following conditions:
• Air bag deployment
• Personal injury
• Unnecessary SIR system repairs
In order to avoid the above conditions, observe the following guidelines:
• Refer to SIR Component Views in order to determine if you are performing service on or near the SIR components or the SIR wiring.
• If you are performing service on or near the SIR components or the SIR wiring, disable the SIR system. Refer to Disabling the SIR System.
Disable the SIR system. Refer to Disabling the SIR System in SIR.
Remove the steering column trim covers from the steering column. Refer to Steering Column Trim Cover Replacement - On Vehicle .
Disconnect the steering column electrical connectors.
Remove the wire harness assembly (1) from the steering column and the wire harness strap (2).
Slide the 2 connectors (2) of the turn signal and multifunction switch assembly out of the bulkhead connector (1).
Remove the key alarm connector (1) from the lock module assembly (2) in the following way:
Rotate the key alarm connector (1) 90 degrees.
Pull the key alarm connector (1) out of the lock module assembly (2).
Remove the passkey connector from the lock module assembly (2).
Remove the connector (2) from the electric park lock (1), for vehicles equipped with floor shifters.
Slide the ignition and key alarm switch assembly (3) out of the lock module assembly (1).
Installation Procedure
Slide the ignition and key alarm switch assembly (3) into the lock module assembly (1).
Install the key alarm connector (1) into the lock module assembly (2).
Push the key alarm connector (1) into the lock module assembly (2).
Rotate the key alarm connector (1) 90 degrees so that the key alarm connector (1) locks into place.
Install the passkey connector into the lock module assembly (2).
Snap the electric park lock (2) onto the lock module assembly (1), for vehicles equipped with floor shifters.
Reconnect the connector (2) to the electric park lock (1), for vehicles equipped with floor shifters.
Slide the 2 connectors (2) of the turn signal and multifunction switch assembly into the bulkhead connector (1).
Attach the wire harness assembly (1) to the steering column wire harness strap (2).
Connect the steering column electrical connectors to the vehicle.
Install the trim covers to the column. Refer to Steering Column Trim Cover Replacement - On Vehicle .
Enable the SIR system. Refer to Enabling the SIR System in SIR.
WOW + Ralph
Thanks for sharing this tip on how to remove the ignition switches. That seems like a good idea to reuse the 2 screws and my friend will be happy. I should do the cutting before i have a couple of beers if i want a straight line
How do you repair the linkage between the ignition switch & the connection in the steering column?
screw it out with a screw driver or ask for help from a mechanic
99 chevy s10 ingtion key switch problem with the key coming out please help me out
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 16
Total : 35,360
