Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
La deuxième génération de l'iPad avec les modèles Wi-Fi, GSM et CDMA. Certains modèles ont été rafraîchis avant l'iPad 3. La réparation est difficile, nécessitant de chauffer les parties collées, ainsi que de la précision et de la concentration afin de judicieusement détacher les différents composants.
Questions au sujet de 988 Voir tout
Help me fix my iPad 2
I dropped my iPad 2 the other week and it was working perfectly fine, I went to go turn it on today and the screen was black and wouldn't turn on. You can here it Charing when you out the charger in but that's about it. Can someone please help me?
Répondre à cette question J'ai le même problème
Indice 1
Commentaires:
how do i fix my iPad 2
par
Patrick Kodi, depends what's wrong with it.
par
Ajouter un commentaire
6 solutions
Réponse la plus utile
It sounds like a problem with the LCD. You will need to remove the screen in the iPad and try reseating the LCD cable in to the motherboard and the back of the LCD. If that doesn't help, you will need to replace the LCD.
Cette réponse a-t-elle été utile ?
Indice 1
I agree with David. See if it's recognized in iTunes. If you can hear it charging, and it's recognized, then it's most likely a display problem. Hopefully the lcd cable came loose. If not, you need a new LCD display. Other than that, could be the backlight, but I'd try the LCD first.
Indice 0
Just my opinion and also I am no expert to this kind of problem just tell me if I went wrong, so I agree with David that the LCD is indeed broken after that damage you did so probably you would have to do a hard reset to make sure that the LCD is back on again by holding down the power button and home button the same time, if it didn't work try taking it to the apple store or replace its LCD.
Indice 0
When I make a video on my iPad 2 am not getting audio but when I listen to music or watch a video am getting audio,can you help me please
Indice 0
Commentaires:
This is a microphone issue
par
Try holding the power button and the home button both at the same time for about 15 seconds. If iPad does not come on the LCD most likely came unplugged after dropped. Very common on this iPad 2. Worst case scenario you will need a new LCD
Indice 0
Disassemble. After checking out the parts, reassemble if broken and send to Apple.
Indice 0
Ajouter une réponse
lani sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 276
